Philco 45C restoration
#32
I've mostly completed the electronic restoration of my 45C.  It sounds surprisingly good!  And, the radio performs with very good sensitivity and selectivity.  I'm fairly impressed and I think you will be as well, morzh (at least I hope so).  My volume control is definitely a problem and I will be looking for a replacement.  The cabinet needs a bit of TLC and I will probably refinish it sometime.
My restoration used most of the old wire except for the high voltage lines.  All tubular capacitors were re-stuffed as were the electrolytics.  All dog bone resistors remain in circuit with an added hidden parallel resistor for those that were way high in value.  I avoided bending the PT wires and coated them with a couple of coats of clear "corona dope" acrylic plastic from GC electronics in the hope that it will add a tiny bit of insulation value.  I need to find a couple of tube shields.
This radio also has the 50K resistor that morzh talked about earlier in this thread.  Mine measures 35K so I added a 15K in series.  This resistor drops the voltage by only about 5 volts so I'm not sure of what its purpose is.  Perhaps to slightly increase field current???  Removing the 15K drops the voltage by another volt or so.  I may just leave it out.
Morzh, do you still need a dial cord diagram?  I could take a couple of pics.  It is quite straight forward.
Here's a few of pics:
Philco 45C restoration - by morzh - 06-12-2019, 07:50 PM
RE: Philco 45C restoration - by morzh - 06-12-2019, 07:53 PM
RE: Philco 45C restoration - by morzh - 06-12-2019, 07:58 PM
RE: Philco 45C restoration - by Radioroslyn - 06-13-2019, 02:38 PM
RE: Philco 45C restoration - by morzh - 06-13-2019, 03:24 PM
RE: Philco 45C restoration - by morzh - 06-13-2019, 09:02 PM
RE: Philco 45C restoration - by morzh - 06-17-2019, 11:27 AM
RE: Philco 45C restoration - by morzh - 06-17-2019, 02:26 PM
RE: Philco 45C restoration - by morzh - 06-19-2019, 09:15 PM
RE: Philco 45C restoration - by morzh - 06-21-2019, 07:52 PM
RE: Philco 45C restoration - by rfeenstra - 06-22-2019, 12:36 PM
RE: Philco 45C restoration - by rfeenstra - 06-22-2019, 01:26 PM
RE: Philco 45C restoration - by morzh - 06-22-2019, 02:58 PM
RE: Philco 45C restoration - by rfeenstra - 06-27-2019, 09:35 PM
RE: Philco 45C restoration - by morzh - 06-28-2019, 10:56 AM
RE: Philco 45C restoration - by rfeenstra - 06-28-2019, 11:28 PM
RE: Philco 45C restoration - by morzh - 06-29-2019, 01:51 PM
RE: Philco 45C restoration - by morzh - 06-29-2019, 08:50 PM
RE: Philco 45C restoration - by morzh - 07-08-2019, 11:01 AM
RE: Philco 45C restoration - by rfeenstra - 07-08-2019, 02:10 PM
RE: Philco 45C restoration - by morzh - 07-08-2019, 03:56 PM
RE: Philco 45C restoration - by rfeenstra - 07-08-2019, 05:35 PM
RE: Philco 45C restoration - by Ron Ramirez - 07-08-2019, 05:38 PM
RE: Philco 45C restoration - by morzh - 07-09-2019, 07:44 AM
RE: Philco 45C restoration - by rfeenstra - 07-09-2019, 12:47 PM
RE: Philco 45C restoration - by morzh - 07-09-2019, 07:45 PM
RE: Philco 45C restoration - by morzh - 07-10-2019, 11:19 AM
RE: Philco 45C restoration - by rfeenstra - 07-10-2019, 01:03 PM
RE: Philco 45C restoration - by morzh - 07-10-2019, 01:44 PM
RE: Philco 45C restoration - by Paul Philco322 - 07-12-2019, 08:33 AM
RE: Philco 45C restoration - by morzh - 07-12-2019, 09:38 AM
RE: Philco 45C restoration - by rfeenstra - 07-12-2019, 03:50 PM
RE: Philco 45C restoration - by morzh - 07-12-2019, 05:49 PM
RE: Philco 45C restoration - by rfeenstra - 07-12-2019, 07:41 PM
RE: Philco 45C restoration - by rfeenstra - 07-12-2019, 08:20 PM
RE: Philco 45C restoration - by morzh - 07-12-2019, 08:20 PM
RE: Philco 45C restoration - by rfeenstra - 07-12-2019, 08:34 PM
RE: Philco 45C restoration - by rfeenstra - 07-12-2019, 10:22 PM
RE: Philco 45C restoration - by Ron Ramirez - 07-12-2019, 10:42 PM
RE: Philco 45C restoration - by morzh - 07-13-2019, 09:36 AM
RE: Philco 45C restoration - by morzh - 07-13-2019, 12:13 PM
RE: Philco 45C restoration - by rfeenstra - 07-13-2019, 01:34 PM
RE: Philco 45C restoration - by morzh - 07-13-2019, 04:17 PM
RE: Philco 45C restoration - by morzh - 07-14-2019, 08:21 PM
RE: Philco 45C restoration - by morzh - 07-17-2019, 08:38 PM
RE: Philco 45C restoration - by rfeenstra - 07-18-2019, 10:16 AM
RE: Philco 45C restoration - by morzh - 07-18-2019, 07:24 PM
RE: Philco 45C restoration - by morzh - 07-18-2019, 08:05 PM
RE: Philco 45C restoration - by rfeenstra - 07-18-2019, 08:30 PM
RE: Philco 45C restoration - by morzh - 07-18-2019, 11:15 PM
RE: Philco 45C restoration - by morzh - 07-27-2019, 08:37 PM
RE: Philco 45C restoration - by rfeenstra - 07-27-2019, 11:49 PM
RE: Philco 45C restoration - by morzh - 07-28-2019, 12:41 AM
RE: Philco 45C restoration - by morzh - 07-28-2019, 08:13 PM
RE: Philco 45C restoration - by morzh - 09-16-2019, 08:19 AM
RE: Philco 45C restoration - by rfeenstra - 09-16-2019, 12:05 PM
RE: Philco 45C restoration - by morzh - 09-16-2019, 12:38 PM
RE: Philco 45C restoration - by Paul Philco322 - 09-16-2019, 08:19 PM
RE: Philco 45C restoration - by morzh - 09-16-2019, 09:32 PM
RE: Philco 45C restoration - by Paul Philco322 - 09-16-2019, 09:49 PM
RE: Philco 45C restoration - by mikethedruid - 09-17-2019, 12:54 AM
RE: Philco 45C restoration - by morzh - 09-17-2019, 07:59 AM
RE: Philco 45C restoration - by morzh - 09-19-2019, 07:20 PM
RE: Philco 45C restoration - by morzh - 09-19-2019, 07:52 PM
RE: Philco 45C restoration - by morzh - 09-19-2019, 08:33 PM
RE: Philco 45C restoration - by morzh - 09-22-2019, 03:48 PM
RE: Philco 45C restoration - by Stall-U-Rated - 09-22-2019, 04:56 PM
RE: Philco 45C restoration - by Ron Ramirez - 09-22-2019, 05:22 PM
RE: Philco 45C restoration - by Stall-U-Rated - 09-22-2019, 05:43 PM
RE: Philco 45C restoration - by morzh - 09-22-2019, 06:28 PM
RE: Philco 45C restoration - by morzh - 09-22-2019, 06:34 PM
RE: Philco 45C restoration - by Ron Ramirez - 09-22-2019, 06:44 PM
RE: Philco 45C restoration - by morzh - 09-22-2019, 07:32 PM
RE: Philco 45C restoration - by Ron Ramirez - 09-23-2019, 09:30 AM
RE: Philco 45C restoration - by morzh - 09-23-2019, 09:54 AM
RE: Philco 45C restoration - by morzh - 09-23-2019, 12:27 PM
RE: Philco 45C restoration - by morzh - 09-24-2019, 11:52 AM
RE: Philco 45C restoration - by Ron Ramirez - 09-24-2019, 12:36 PM
RE: Philco 45C restoration - by morzh - 09-24-2019, 12:51 PM
RE: Philco 45C restoration - by Ron Ramirez - 09-24-2019, 12:55 PM
RE: Philco 45C restoration - by morzh - 09-24-2019, 01:24 PM
RE: Philco 45C restoration - by Ron Ramirez - 09-24-2019, 03:10 PM
Users browsing this thread: 30 Guest(s)
