Grill cloth.
We pick up KHDN Billings, MT readily on HER radio.  All we have to do is move the radio around for best reception while tuning in the station.  It sure pick it up nicely here in Sheridan, WY; over 125 miles away.  It does great DX'ing after dark... (She solved the problem) she also just found the factory-optional external plugin for it.  It has a switch for distant and local stations.  You connect a wire antenna to it, and run it outside.  WOW!!
The station was assigned the call letters KHDN in 1963. The call letters changed to KYTY on August 10, 1984. On September 10, 1986, the station changed its call sign to KBSR, on March 28, 1989, to KKUL, and on June 1, 1995 to the current KHDN.  (a bit of history here).
[url=https://en.wikipedia.org/wiki/KHDN#cite_note-2][/url]
Respectfully,
Cliff & Sheila Byers
Grill cloth. - by jake wells - 06-03-2019, 11:35 PM
RE: Grill cloth. - by Radioroslyn - 06-04-2019, 06:35 AM
RE: Grill cloth. - by jake wells - 06-04-2019, 03:30 PM
RE: Grill cloth. - by Cliff Byers - 07-12-2019, 09:00 AM
RE: Grill cloth. - by Cliff Byers - 07-12-2019, 09:02 AM
RE: Grill cloth. - by morzh - 07-12-2019, 06:12 PM
RE: Grill cloth. - by Cliff Byers - 07-12-2019, 08:56 PM
RE: Grill cloth. - by Paul Philco322 - 07-12-2019, 09:11 PM
RE: Grill cloth. - by Cliff Byers - 07-12-2019, 09:55 PM
RE: Grill cloth. - by Radioroslyn - 07-13-2019, 09:43 AM
RE: Grill cloth. - by Cliff Byers - 07-13-2019, 05:52 PM
RE: Grill cloth. - by Radioroslyn - 07-13-2019, 06:56 PM
RE: Grill cloth. - by Cliff Byers - 07-14-2019, 10:52 AM
