Philco Skyscraper 40-190 find
It's missing all of the station labels. Anyone well them, or do people make their own out of some sort of plastic?
Philco Skyscraper 40-190 find - by rdnzl - 07-13-2019, 08:19 PM
RE: Philco Skyscraper 40-190 find - by morzh - 07-13-2019, 08:54 PM
RE: Philco Skyscraper 40-190 find - by rdnzl - 07-13-2019, 09:26 PM
RE: Philco Skyscraper 40-190 find - by Chas - 07-13-2019, 09:54 PM
Philco 91 Tuning Condenser
There are currently 10119 online users. [Complete List]
» 2 Member(s) | 10117 Guest(s)
