Another noob with another Philco!
I may just do that Larry, thanks for the offer.  It may be a bit.
You can call me Jerry if you don't want to use my handle.  I get it.  Makes some folks nervous.
I have a finely tuned horse puckey detector.  Don't blame me if it goes off. Oldtimer
RE: Another noob with another Philco! - by David - 12-12-2018, 09:34 AM
RE: Another noob with another Philco! - by morzh - 12-12-2018, 11:18 AM
Tube testing - by atlghosthunter - 01-05-2019, 04:27 AM
RE: Another noob with another Philco! - by atlghosthunter - 07-16-2019, 08:56 PM
There are currently 8725 online users. [Complete List]
» 2 Member(s) | 8723 Guest(s)
