37-84 Code 121 Dial Lamp ?
Hello, I have a 37-84 Code 121 Radio. I bought it this week. My Dial Lamp bulb is not working. It worked briefly for about 30 seconds. Then it stopped. I took the bulb out and is says 6-8 Volt Ray. The filliment looks good. Nothing is broken inside the bulb. Is the 6-8 Volt Ray the correct bulb for the 37-84? I want to get a replacement bulb first before I get into the connections. Thank for your help!
37-84 Code 121 Dial Lamp ? - by David77 - 07-21-2019, 02:56 PM
RE: 37-84 Code 121 Dial Lamp ? - by KCMike - 07-21-2019, 05:53 PM
RE: 37-84 Code 121 Dial Lamp ? - by David77 - 07-21-2019, 05:59 PM
RE: 37-84 Code 121 Dial Lamp ? - by Steve Davis - 07-21-2019, 09:30 PM
91H Code 126 Restore
There are currently 2946 online users. [Complete List]
» 2 Member(s) | 2944 Guest(s)
