Unknown cathedral radio... HELP !
I used Sound Remedy to rebuild an Arvin Rhythm Baby speaker that had no cone or voice coil and they used a new voice coil and did a great job. I don't know if they wound the coil themselves or purchased it though.
Steve D
RE: Unknown cathedral radio... HELP ! - by KCMike - 07-01-2019, 08:04 AM
RE: Unknown cathedral radio... HELP ! - by Steve D - 07-22-2019, 05:22 PM
There are currently 10761 online users. [Complete List]
» 3 Member(s) | 10758 Guest(s)
