The BBC tests of a 48/482 Philco US model
Hi Folks,
While trawling the net for other radio related stuff, I happened upon the BBC R&D department website. This has an archive of BBC white papers, covering all sorts of technical aspects of television and radio, and contains publications back to 1940.
While interesting in itself, I happened upon an item of direct Philco relevance, in which the FM section of the 48/482 AM/FM receiver was tested.
The decade by decade archive starting point is available here:
https://www.bbc.co.uk/rd/search?Type=Publications
And the Philco specific paper is here:
https://www.bbc.co.uk/rd/publications/rdreport_1949_11
I hope this is of interest to the Phorum.
Cheers
Ed
The BBC tests of a 48/482 Philco US model - by EdHolland - 07-24-2019, 02:42 PM
There are currently 4207 online users. [Complete List]
» 3 Member(s) | 4204 Guest(s)
