The BBC tests of a 48/482 Philco US model
Interesting. Thanks for sharing, Ed.
No surprise to me about the 48-482's discriminator being found as inferior. Philco was trying to circumvent Armstrong's FM patents to avoid paying royalties.
I am rather surprised, though, that the American 48-482 would be available in Britain at all, and that the BBC would test it.
RE: The BBC tests of a 48/482 Philco US model - by Ron Ramirez - 07-24-2019, 06:13 PM
Philco 91 Tuning Condenser
There are currently 9143 online users. [Complete List]
» 1 Member(s) | 9142 Guest(s)
