Dim bulb and Philco 16, code 122 question
Yes, when I power up using a variac and ammeter I never use a dim bulb with it, but I guess it adds another layer of safety against burning out a xfrmr.  You just have to be aware of the voltage drop.
RE: Dim bulb and Philco 16, code 122 question - by Eliot Ness - 07-28-2019, 08:10 AM
