Philco 48-1262 recap job gone bad--Please HELP!!!!!!!!!!
Everything seems fine. I am wondering if it is the antenna. I do not have the original antenna, but I have the cardboard that it was attached to. Do you know hom many loops were used on this radio. I think that with out the pproper antenna the radio will not work properly. I am also still wondering about those capacitors tha had the coils on them.
Thanks
David
[No subject] - by Chuck Schwark - 02-18-2006, 03:48 PM
[No subject] - by Guest - 02-18-2006, 04:02 PM
[No subject] - by Chuck Schwark - 02-18-2006, 04:45 PM
[No subject] - by Guest - 02-20-2006, 01:26 AM
[No subject] - by Chuck Schwark - 02-20-2006, 10:04 AM
