Realistic DX-302 - MHz will not change
Ide cruise youtube... I know they have a topic on how to modify the audio circuit for better sound. Perhaps theres a video to conquer a collar fix there..
I have one of these units, theyre pretty cool.. Icon_biggrin
RE: Realistic DX-302 - MHz will not change - by Stall-U-Rated - 07-30-2019, 11:50 PM
