Magnavox Regency Symphony, 1947?
Hi
O K on the recap and rebuilt cart. I would like to know how the rebuilt cart works. O K on getting a changer. Your magnavox looks good in the pictures. The changer I have is the two speed I think it is the 256 I won it on ebay for 99 cents I found new rubber mounts from Gary (The VM guy) and I have taken it apart and cleaned and lubed it. It has something missing in the power switching I cannot determine what it is yet I think it is some kind of AC switch. But it is in very good shape. I also won the bid on a FM unit which was missing a power transformer and choke, I had both and they fit just as the orignal, I replaced most of the tubes and recapped (most of the caps were cracked they were the square type) it and it came on very strong, it is very sensitive and very stable.
I have bent your ears enough so
Merry Christmas to all
Joe
Magnavox Regency Symphony, 1947? - by Ron Ramirez - 10-19-2010, 09:03 AM
Re: Magnavox Regency Symphony, 1947? - by denver - 10-19-2010, 09:16 AM
Re: Magnavox Regency Symphony, 1947? - by denver - 10-19-2010, 01:56 PM
Re: Magnavox Regency Symphony, 1947? - by denver - 10-19-2010, 09:32 PM
Re: Magnavox Regency Symphony, 1947? - by Jayce - 10-20-2010, 07:57 PM
Re: Magnavox Regency Symphony, 1947? - by Jayce - 10-21-2010, 06:15 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 10-26-2010, 01:13 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 10-28-2010, 10:06 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 11-17-2010, 02:37 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 12-05-2010, 07:30 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 12-16-2010, 04:26 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 01-21-2011, 07:48 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-03-2011, 05:02 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-03-2011, 06:58 PM
Re: Magnavox Regency Symphony, 1947? - by PFJC2 - 02-06-2011, 10:08 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-07-2011, 10:16 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-09-2011, 12:18 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-09-2011, 03:37 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-09-2011, 03:39 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-10-2011, 12:16 AM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-10-2011, 12:54 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-25-2011, 07:23 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 03-03-2011, 10:45 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 03-04-2011, 05:29 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 03-04-2011, 09:30 PM
Eico 232 VTVM Schematic
There are currently 8942 online users. [Complete List]
» 1 Member(s) | 8941 Guest(s)
