Looking for a communications receiver?
Back when I was a teen, almost 300 years ago too, I built a Knight Kit Star Roamer, a five bad radio with a long wave band on it also. I still have that radio but as far as performance goes, meh. I guess you can't expect much from a 4 tuber with selenium rectifier. Today one of my Philcos, a 41-250 is pretty decent. Also I have 2 Zenith Trans Oceanics that I like, one I'm redoing for my brother. I don't have a Hali or Hammerlund to compare to. There's not near  as much on sw like when I was young.
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
RE: Looking for a communications receiver? - by 462ron - 08-03-2019, 09:22 AM
