Looking for a communications receiver?
Terry, 1969 sounds about right for me too. I dug it out about 2 years ago and had to replace the electrolytic, did an alignment on it too.
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
RE: Looking for a communications receiver? - by 462ron - 08-03-2019, 09:37 AM
