Looking for a communications receiver?
Back in the early 70's I went to a auction at the Navy yard in Washington DC and came away w/ a half doz of '180s. The issue was that they had been stored outside hit w/a wrecking ball. Was able to get abt half working and passed them along.
RE: Looking for a communications receiver? - by Radioroslyn - 08-03-2019, 12:39 PM
