Problems with 116b after chassis cleaning
If your Shadow Meter coil is partially shorted and has less thatn the nominal resistance, you can re-wind the coil.
See my Service Tip No.1 on my site: http://www.philcorepairbench.com/tips/svctip01.htm
The newer type meter coil should have approx. 10 ma. of current thru it to properly swing the vane and that's about
A 10 V. drop, so Georg Simon Ohm's law says the coil resistance should be approx. 1000 ohms. If your coil is appreciably
less, then I'd suspect shorted turns. That's about 900 turns od AWG 40 wire.
Chuck
Re: Problems with 116b after chassis cleaning - by Chuck Schwark - 12-17-2010, 10:48 AM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 6254 online users. [Complete List]
» 2 Member(s) | 6252 Guest(s)
