Looking for a communications receiver?
Another neat thing in my radio room is a world clock that I'm rebuilding now. It's called a Geochron and gives time around the globe as well as day/night, position of the sun in the sky (analemma) and other things. I serviced it about 10 years ago but this time it needs a few items replaced from the heat of the two fluorescent lamps inside. The first thing I did was change out the lamp units to use LED lamps. It will run cool now. I'm replacing the sun shades, diffusers and I'm getting a new updated moving map.
The Geochron was great when I used to DX SW.
Here it is apart....well the rear of the unit......
And together...
RE: Looking for a communications receiver? - by thirtiesradio - 08-04-2019, 02:05 AM
