Please ID Silvertone
It's a King-Hinner set made for Silvertone. I have this one:
[Image: https://proxy.duckduckgo.com/iu/?u=http%...up.jpg&f=1]
Pic stolen from the net.
Don't know if there is a diagram for it but there is not must difference between most of the battery Neutrodyne TRF sets. This will get you in the ballpark: http://www.nostalgiaair.org/pagesbymodel...017930.pdf
The tricky part on this one is getting the chassis out. It comes out thru the front but you have to remove the wood trim to access the screws along the edge of the panel.
GLOM
Please ID Silvertone - by vecher - 08-09-2019, 04:11 PM
RE: Please ID Silvertone - by Radioroslyn - 08-09-2019, 04:51 PM
RE: Please ID Silvertone - by vecher - 08-09-2019, 08:39 PM
RE: Please ID Silvertone - by Chas - 08-09-2019, 10:14 PM
