which one???
+1 Ron
But if you don't mind having a tombstone the early '36 116B is the one to get. The 10 1/2" H spkr can handle the 10w output stage a little better that the 8" K spkr. It looks like the design is a work in progress on the 16B code 121 ('33 cathedral) as there a lot of updates in the service notes. The later runs of the 16B and the 116B have a much more effective tone control circuit than the code 121 (the '33 cathedral) pretty much just cuts the high frequency response from the audio.
On the rf/if side of things the later runs have a rf amp where the code 121 has the qave circuit. The alignment on the later runs is more straight forward and helps to make the set more accurate.
GL on your search!
which one??? - by falcon123 - 08-20-2019, 04:21 AM
RE: which one??? - by Jake Blake - 08-20-2019, 07:35 AM
RE: which one??? - by falcon123 - 08-20-2019, 08:17 AM
RE: which one??? - by Jake Blake - 08-20-2019, 08:40 AM
RE: which one??? - by Jake Blake - 08-20-2019, 08:41 AM
RE: which one??? - by Radioroslyn - 08-20-2019, 09:47 AM
RE: which one??? - by Ron Ramirez - 08-20-2019, 02:02 PM
RE: which one??? - by GarySP - 08-21-2019, 10:51 AM
RE: which one??? - by falcon123 - 08-22-2019, 03:47 AM
RE: which one??? - by Jake Blake - 08-22-2019, 10:11 AM
Philco 91 Tuning Condenser
There are currently 10141 online users. [Complete List]
» 2 Member(s) | 10139 Guest(s)
