53-960 found
I bought this Saturday (8/17/2019) at the SCARS swap meet.  I need the tone-off knob and the back.  Do you think they considered having FM?  It has a large blank space beside the tuning gang, perhaps for a separate FM tuning gang they decided not to use...
 [Image: https://i269.photobucket.com/albums/jj77...age004.jpg]
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
53-960 found - by FStephenMasek - 08-21-2019, 12:00 AM
RE: 53-960 found - by Simon Wa3uay - 08-21-2019, 08:32 PM
RE: 53-960 found - by Steve Chambers - 08-22-2019, 12:31 PM
RE: 53-960 found - by Ron Ramirez - 08-22-2019, 06:56 PM
There are currently 7603 online users. [Complete List]
» 2 Member(s) | 7601 Guest(s)
