37-650 Current Symptoms
Go and do what Chuck has suggested, which is excellent advice.
There is a remote possibility that you may have a burn (carbon track) on one of the switch wafers. This happened to me on a 37-650 last year. As with your radio, this set initially tried to work, then quit. Eventually, and by sheer luck, I found (via continuity checks which Chuck has suggested that you do, and this is one reason why you need to do this) that a carbon track had formed from B+ to ground on one of the oscillator section switch wafers, and had burned a pit in the phenolic. Using a sharp knife, I scraped out the carbon until I had no continuity between the terminals where the track had formed. I then filled the cut area and the pit with epoxy. Reassembled, end of problem.
Diagnosing and repairing a carbon track is not a job for a novice; it isn't easy for someone who has been doing this for years, either, believe me. Good luck. You may need an Elmer on this job.
37-650 Current Symptoms - by Robbie Roberts - 02-19-2006, 07:59 PM
[No subject] - by Robbie Roberts - 02-20-2006, 12:59 AM
[No subject] - by Robbie Roberts - 02-20-2006, 03:01 AM
[No subject] - by Chuck Schwark - 02-20-2006, 10:05 AM
[No subject] - by Robbie Roberts - 02-20-2006, 10:43 AM
[No subject] - by Chuck Schwark - 02-20-2006, 10:55 AM
[No subject] - by Robbie Roberts - 02-20-2006, 11:15 AM
[No subject] - by Ron Ramirez - 02-20-2006, 11:33 AM
[No subject] - by Robbie Roberts - 02-20-2006, 11:36 AM
[No subject] - by Ron Ramirez - 02-20-2006, 03:37 PM
[No subject] - by Robbie Roberts - 02-21-2006, 01:01 AM
More info - by Robbie Roberts - 02-21-2006, 11:05 AM
Further Results - by Robbie Roberts - 02-21-2006, 11:54 AM
Philco 91 Tuning Condenser
There are currently 8869 online users. [Complete List]
» 1 Member(s) | 8868 Guest(s)
