46-1226 run 122 with squeal
Squealing problem has been solved. Thanks to a post on this radio over on ARF, I found that the output transformer had been replaced at some point and they had reversed the primary leads. This led to the radio having positive feedback instead of negative. What actually clued us in was by grounding the bottom side of the volume control the squealing stopped. Removing the ground with the radio powered up brought the squeal back. Reversing the primary leads solved it.
46-1226 run 122 with squeal - by Jim Dutridge - 12-21-2010, 09:11 AM
Re: 46-1226 run 122 with squeal - by Ron Ramirez - 12-21-2010, 09:37 AM
Re: 46-1226 run 122 with squeal - by Jim Dutridge - 12-21-2010, 10:22 AM
Re: 46-1226 run 122 with squeal - by Jim Dutridge - 12-21-2010, 01:52 PM
Re: 46-1226 run 122 with squeal - by Ron Ramirez - 12-26-2010, 09:22 AM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 4682 online users. [Complete List]
» 2 Member(s) | 4680 Guest(s)
