Unknown cathedral radio... HELP !
In my case I don't think it is the RF being too strong, I think it is that the circuit isn't handling it properly. The 10K pot may solve this because it affects the bias on the grids of the two type 57 tubes. We'll see.
RE: Unknown cathedral radio... HELP ! - by KCMike - 07-01-2019, 08:04 AM
RE: Unknown cathedral radio... HELP ! - by mikethedruid - 08-27-2019, 05:39 PM
There are currently 10795 online users. [Complete List]
» 2 Member(s) | 10793 Guest(s)
