Unknown cathedral radio... HELP !
The 10K pot for the volume control arrived today. I undid the experimenting with bias that I had been doing for a while, and returned everything to the Jackson Bell Model 4 schematic. The radio actually works the best it has since I got it. The odd "motorboating is gone, and I am able to pick up a number of stations at night with my outdoor antenna. The volume is not very loud, but at least it now works.
[Image: https://66.media.tumblr.com/2c445a32e0e3...1_1280.jpg]
RE: Unknown cathedral radio... HELP ! - by KCMike - 07-01-2019, 08:04 AM
RE: Unknown cathedral radio... HELP ! - by mikethedruid - 08-30-2019, 08:39 PM
There are currently 10385 online users. [Complete List]
» 1 Member(s) | 10384 Guest(s)
