41-608 phono question
Thank you for the information. I would however like an explanation of what the selector buttons do as well as any adjustments that may be needed. Right now I can't get the record off the turntable, as the lever arms are in a position to block it.......Stupid I know, also when it is on, the tonearm tracks out too far to drop down on the record, and it does not park itself over far enough when record is complete.......
41-608 phono question - by Guest - 02-19-2006, 10:15 PM
[No subject] - by Chuck Schwark - 02-19-2006, 10:34 PM
[No subject] - by Guest - 02-20-2006, 12:42 PM
[No subject] - by Chuck Schwark - 02-21-2006, 10:35 PM
There are currently 10534 online users. [Complete List]
» 2 Member(s) | 10532 Guest(s)
