Unknown cathedral radio... HELP !
#35
"Jake, the 45k is part of a voltage divider formed by it and the 20k 5w."
Thanks.
If I'm understanding correctly, they  create a current draw with more than one, stable voltage at different points along it?
RE: Unknown cathedral radio... HELP ! - by KCMike - 07-01-2019, 08:04 AM
RE: Unknown cathedral radio... HELP ! - by Jake Blake - 08-31-2019, 10:06 AM
There are currently 10481 online users. [Complete List]
» 2 Member(s) | 10479 Guest(s)
