Threads: 114
City: Sneedville, TN
Thanks, Jake. Actually, I was able to leave the original cans in place, and put the 3 new electrolytics under the chassis. From the top it looks just like it did before, except it is a LOT cleaner. I even cleaned out the 3 sections of the variable condenser using isopropyl alcohol and Dill's pipe cleaners. Today I gave the case a second scrubbing with white Go-Jo and steel wool. Yesterday I gave it it's first rub down which got off a LOT of old dead finish, and a lot of yellow nicotine and dirt that had accumulated. I noticed that there were still some spots of white paint on it after that, so today I gave it a second scrubbing with the steel wool and got off all that paint. The case looks quite good. There are a few small areas where the veneer is chipped off on the sides, but I am going to leave them alone. I'll be the first to admit I am not really much of a wood worker. They are hardly noticeable, and are "battle scars" that I'm not too concerned about. I am not really trying to make this radio look new. I am just making it look presentable again, and making it work as well as it did when new. After it has dried for a few days I'll rub it down with a coat of tung oil, give that a few days to dry then repeat as necessary until the finish is restored.
[split] New member...
The gear on the 37-604 is exact same, but there was no pin.
The pin exists on the gear of 37-116 or those ones with rob...morzh — 04:31 PM |
I agree, the two should not be connected. Due to poor image quality of the original Philco schematic, it was unclear if ...jrblasde — 02:25 PM |
New 37-116 Parts
Dan,
I'm curious, I saw the 38-2 dial you got from them. Are you getting a new, improved one from them without the wh...Greg — 01:59 PM |
New 37-116 Parts
They are not closed. I sent an email to them 3/8/2025 and got a reply back 3/10/2025. Since 3/8/2025 was a Saturday I di...dconant — 01:22 PM |
Gloritone 27 Radio
Hello, The radio is playing now using the repaired antenna coil.
MrFixr55 you stated a while back I might need to add...dconant — 01:10 PM |
New 37-116 Parts
Well, their answering machine says they check their messages every day at noon and respond by 3p the next day - I can sa...Doppleganger — 01:09 PM |
Thanks 462ron. I have it soaking right now but will test the power of my shop light magnet on the pin when it comes out.HowardWoodard — 11:39 AM |
Wasn't that the Suppressor grid that we were talking about, that got connected with the AVC?
Anywho, the initial questi...morzh — 10:53 AM |
Hi Howard, if memory serves, and many times it doesn’t, I vaguely remember working on a Philco that had that pin you hav...462ron — 09:00 AM |
Gloritone 27 Radio
Hello John,
Thanks for the information and Arran I have heard of Wells Gardner and I have heard of Apex but I did not ...radiorich — 08:17 AM |
There are currently 2612 online users. [Complete List] » 1 Member(s) | 2611 Guest(s)
