Found: Philco 37-690!
Nice! I'm still looking for my 38-690! I think it would stand up well next to my EH Scotts. I've heard one and it sounds great (mp3 input). My 37-116 sounds very good without the tweeters and the separate amplifier.
Found: Philco 37-690! - by amglow - 09-13-2019, 09:20 PM
RE: Found: Philco 37-690! - by amglow - 09-13-2019, 09:41 PM
RE: Found: Philco 37-690! - by Ron Ramirez - 09-13-2019, 10:00 PM
RE: Found: Philco 37-690! - by amglow - 09-13-2019, 10:09 PM
RE: Found: Philco 37-690! - by rfeenstra - 09-13-2019, 11:52 PM
RE: Found: Philco 37-690! - by OldRestorer - 09-14-2019, 01:53 AM
RE: Found: Philco 37-690! - by tbone - 09-14-2019, 06:48 AM
RE: Found: Philco 37-690! - by PhilcoJohn - 09-14-2019, 08:49 AM
RE: Found: Philco 37-690! - by klondike98 - 09-14-2019, 07:24 PM
RE: Found: Philco 37-690! - by morzh - 09-15-2019, 11:07 AM
RE: Found: Philco 37-690! - by Scott D - 10-16-2019, 05:33 PM
RE: Found: Philco 37-690! - by mikethedruid - 10-16-2019, 06:28 PM
RE: Found: Philco 37-690! - by Brad Winder - 10-17-2019, 09:01 AM
Philco 91 Tuning Condenser
