My newly restored Philco 49-1401
Yes I should have said the 1948 model 1201 and 1948 - 49 model 1401's use those mini IF cans that are prone to silver mica. Never had that happen on the 1946-47 model 1201's, as they use the larger IF cans, but my 49-1401 has that familiar whoosing / crackling sound at low volume.
My newly restored Philco 49-1401 - by OldRestorer - 08-26-2019, 12:29 PM
RE: My newly restored Philco 49-1401 - by Squire - 08-26-2019, 08:37 PM
RE: My newly restored Philco 49-1401 - by KCMike - 08-26-2019, 09:27 PM
RE: My newly restored Philco 49-1401 - by NostalgiaRadioTime - 09-14-2019, 07:19 PM
