Help identifying cartridge/needle
I recently found a Zenith record player with a VM changer, but I think the cart is bad. I have looked up on the VM website, and have the Sams on both the unit and changer (generic) but cannot find a good match. It is a needle/cartridge unit that plugs in. I have some pics. It is NOT a 993-ds13 (95D), tried one which looked the same in the pictures, but wont fit. Hope someone can help (Kirk  Icon_wink ) Model is HFY12R
It looks like a 940 or 943 is possible, but I cannot really tell from the pictures provided.
Tim
Help identifying cartridge/needle - by TV MAN - 09-16-2019, 07:56 PM
RE: Help identifying cartridge/needle - by TV MAN - 09-17-2019, 12:49 PM
RE: Help identifying cartridge/needle - by TV MAN - 09-17-2019, 06:20 PM
There are currently 10020 online users. [Complete List]
» 2 Member(s) | 10018 Guest(s)
