Hammarlund HQ-129-X
Okay!
So I wanted to have a proper 6x9 speaker in the speaker box Debbie had given me. It needed to be very low impedance (3.2 or 4 ohms). The box had a speaker in it originally, but it was 8 ohms.
I removed that speaker.
Today, a replacement arrived from Parts Express.
https://www.parts-express.com/grs-69as-4...m--292-459
4 ohms! Icon_smile
One problem, though - that extra thick plastic gasket kept me from being able to mount the speaker in the cabinet! Icon_eek The thickness of that gasket would not allow the mounting studs to protrude through to the back of the speaker enough to mount the nuts which hold the speaker in place.
So I decided to try to remove the gasket.
Working very carefully, I was able to pry it off successfully without damaging the cone surround. Then I could easily mount the speaker in the box.
Now, with this 4 ohm 6x9 speaker, the Hammarlund has plenty of volume. Icon_thumbup Yes, now I can actually turn down the volume on strong stations. WRMI in the 31m band is coming in LOUD and clear right now as I type this. Icon_thumbup And I'm not using my outdoor longwire either - I'm using my short (approx. 20 foot) indoor wire antenna which is strung along the ceiling here in the basement.
Hammarlund HQ-129-X - by Ron Ramirez - 08-28-2019, 06:33 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 08-28-2019, 06:45 PM
RE: Hammarlund HQ-129-X - by rfeenstra - 08-28-2019, 07:42 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 08-28-2019, 07:49 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-01-2019, 09:14 PM
RE: Hammarlund HQ-129-X - by John Bartley - 09-02-2019, 08:27 AM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-02-2019, 07:38 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-02-2019, 07:42 PM
RE: Hammarlund HQ-129-X - by mikethedruid - 09-02-2019, 07:49 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-02-2019, 09:29 PM
RE: Hammarlund HQ-129-X - by Paul Philco322 - 09-02-2019, 09:48 PM
RE: Hammarlund HQ-129-X - by mikethedruid - 09-03-2019, 12:04 AM
RE: Hammarlund HQ-129-X - by Eliot Ness - 09-03-2019, 01:03 AM
RE: Hammarlund HQ-129-X - by EdHolland - 09-04-2019, 02:12 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-14-2019, 08:58 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-14-2019, 09:07 PM
RE: Hammarlund HQ-129-X - by Radioroslyn - 09-14-2019, 09:19 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-14-2019, 09:22 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-14-2019, 10:46 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-14-2019, 10:47 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-15-2019, 05:53 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-15-2019, 07:44 PM
RE: Hammarlund HQ-129-X - by Paul Philco322 - 09-15-2019, 08:09 PM
RE: Hammarlund HQ-129-X - by Simon Wa3uay - 09-15-2019, 08:22 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-15-2019, 09:26 PM
RE: Hammarlund HQ-129-X - by Simon Wa3uay - 09-16-2019, 04:44 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-17-2019, 06:56 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-17-2019, 07:03 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-19-2019, 10:00 PM
RE: Hammarlund HQ-129-X - by EdHolland - 09-20-2019, 01:47 PM
RE: Hammarlund HQ-129-X - by Simon Wa3uay - 09-20-2019, 07:10 PM
RE: Hammarlund HQ-129-X - by rfeenstra - 09-20-2019, 08:51 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-20-2019, 10:43 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-21-2019, 07:57 PM
RE: Hammarlund HQ-129-X - by rfeenstra - 09-21-2019, 08:10 PM
RE: Hammarlund HQ-129-X - by Simon Wa3uay - 09-22-2019, 07:06 PM
RE: Hammarlund HQ-129-X - by Ron Ramirez - 09-23-2019, 09:21 AM
RE: Hammarlund HQ-129-X - by kj0002 - 01-05-2020, 09:34 PM
RE: Hammarlund HQ-129-X - by Paul Philco322 - 01-05-2020, 09:55 PM
Users browsing this thread: 19 Guest(s)
Canadian GE Model 41
Umm....you do not clean potentiometers with contact cleaner. Unless cleaning the carbon layer of the base is the goal. Y...morzh — 05:52 PM
I got the tube tested and it was TU. I have installed a replacement tube. During this last effort I discovered part of...Mtmattking — 04:01 PM
Restoring Philco 96
I opened up and lubed the volume pot. It is suposed to be 500K (no one expects it to be that), and it is about 1.5M. T...morzh — 03:34 PM
Compatible crts
The 5JP1 sounds like either like a military tube, or one built for some piece of older industrial equipment.Arran — 02:59 PM
Thank you morzh. I will try that today.R3Sons — 02:06 PM
A man who repairs tube radios is capable of many things. Capable of anything :lol: Beware.morzh — 01:40 PM
Philco 91 Tuning Condenser
Yes, in those it is. In 20/90 it is a metal spring that holds the rotor in the cradles of the outer walls.morzh — 01:39 PM
There are currently 2164 online users. [Complete List]
» 1 Member(s) | 2163 Guest(s)
