vacuum tube top question
You should be able to resolder the cap to the wire. If the wire is too short you can solder on an extension of small wire.
Heat up the top cap separately and shake off the old solder. You should see a little pinhole where the wire goes thru.
Hope that helps.
-Bill
vacuum tube top question - by radionoob - 12-27-2010, 05:56 AM
Re: vacuum tube top question - by exray - 12-27-2010, 09:32 AM
Re: vacuum tube top question - by Alan Douglas - 12-29-2010, 09:54 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 6273 online users. [Complete List]
» 2 Member(s) | 6271 Guest(s)
