Help looking for a grill cloth
It isn't.
There are several different versions of the 89B.
https://philcoradio.com/library/index.ph...-model-89/
The first three cathedral cabinets shown use what is commonly known as "70/90" grille cloth because it is the same pattern used in model 70 and 90 cathedrals.
Exact duplicates of this cloth are no longer available. Close substitutes:
http://www.radiodaze.com/grille-cloth-02-item-grc02/
https://www.ebay.com/itm/183963258584
The June 1934 version used a diamond pattern similar to this:
http://www.radiodaze.com/grille-cloth-05-item-grc05/
Note that the green stripes should be vertical, not horizontal.
And the final version (January 1936) used what is commonly known as "Ribbed" cloth. A close substitute:
http://www.radiodaze.com/grille-cloth-14-item-grc14/
Help looking for a grill cloth - by Denny - 09-22-2019, 12:50 PM
RE: Help looking for a grill cloth - by Denny - 09-22-2019, 02:38 PM
RE: Help looking for a grill cloth - by Denny - 09-22-2019, 03:52 PM
RE: Help looking for a grill cloth - by Ron Ramirez - 09-22-2019, 05:17 PM
There are currently 4533 online users. [Complete List]
» 1 Member(s) | 4532 Guest(s)
