Model 29TX Find this weekend
...and the one I sold to Kirk has a rough cabinet and is missing the back.
Congratulations on your find, N6MKC! $700 for the entire set with speaker is mere conjecture by someone living in dreamland. Kirk's quotes are more realistic.
Perhaps you could make a tracing of the back for your set and send to Kirk? I'm sure he would appreciate it. Icon_smile
Model 29TX Find this weekend - by N6MKC - 09-23-2019, 05:50 PM
RE: Model 29TX Find this weekend - by Denny - 09-24-2019, 04:22 PM
RE: Model 29TX Find this weekend - by morzh - 09-24-2019, 04:54 PM
RE: Model 29TX Find this weekend - by OldRestorer - 09-24-2019, 05:06 PM
RE: Model 29TX Find this weekend - by morzh - 09-24-2019, 11:20 PM
RE: Model 29TX Find this weekend - by Ron Ramirez - 09-25-2019, 09:24 AM
RE: Model 29TX Find this weekend - by OldRestorer - 09-25-2019, 09:55 AM
Philco 91 Tuning Condenser
There are currently 9421 online users. [Complete List]
» 1 Member(s) | 9420 Guest(s)
