Philco Rolltop Model 10647E
A few questions.
Does anyone know the date for this model;?
I turned it on and it hummed but I received no station.
It appears that a component is missing ( by opening the back ).  There is a hanging 5 prong connector.  Is something missing?  There is a large empty space at the bottom of the cabinet.
Anyone?
Philco Rolltop Model 10647E - by Archy - 09-26-2019, 02:16 PM
RE: Philco Rolltop Model 10647E - by Archy - 09-26-2019, 02:38 PM
RE: Philco Rolltop Model 10647E - by Archy - 09-26-2019, 03:04 PM
RE: Philco Rolltop Model 10647E - by OldRestorer - 09-26-2019, 04:11 PM
There are currently 4968 online users. [Complete List]
» 1 Member(s) | 4967 Guest(s)
