Philco Rolltop Model 10647E
Hi Archy -
The number 10647E doesn't sound like a model number. Do you have a photo you could share?
Philco made a couple of different 'rolltop' models. From your description it sounds like it might be a console model - perhaps a 38-690?
https://philcoradio.com/gallery2/1938a/#Model_38-690XX
For portable units there's models like the 46-350:
https://philcoradio.com/gallery2/1946a/#Model_46-350
Philco Rolltop Model 10647E - by Archy - 09-26-2019, 02:16 PM
RE: Philco Rolltop Model 10647E - by Nathan Slingerland - 09-26-2019, 02:30 PM
RE: Philco Rolltop Model 10647E - by Archy - 09-26-2019, 02:38 PM
RE: Philco Rolltop Model 10647E - by Archy - 09-26-2019, 03:04 PM
RE: Philco Rolltop Model 10647E - by OldRestorer - 09-26-2019, 04:11 PM
Philco 91 Tuning Condenser
