David Bogen Tuner and Amps
I took a peek at one of the amps yesterday, just to remember what is on the chassis. For a mono design, there is a decent power transformer and good sized output. Alas, there are no less than three electrolytic cans, two on insulating bases and with cardboard sleeves. I think, once I get both recapped, the first song to play will be Chubby Checker's "Let's Do the Twist" (lock).  Icon_e_biggrin
David Bogen Tuner and Amps - by EdHolland - 09-17-2019, 01:24 PM
RE: David Bogen Tuner and Amps - by Jake Blake - 09-17-2019, 02:00 PM
RE: David Bogen Tuner and Amps - by mikethedruid - 09-17-2019, 02:02 PM
RE: David Bogen Tuner and Amps - by EdHolland - 09-17-2019, 07:43 PM
RE: David Bogen Tuner and Amps - by EdHolland - 09-27-2019, 10:55 AM
RE: David Bogen Tuner and Amps - by Jake Blake - 09-27-2019, 02:50 PM
RE: David Bogen Tuner and Amps - by EdHolland - 01-24-2020, 05:09 PM
RE: David Bogen Tuner and Amps - by EdHolland - 04-10-2020, 09:29 PM
RE: David Bogen Tuner and Amps - by RodB - 04-12-2020, 09:37 AM
RE: David Bogen Tuner and Amps - by EdHolland - 11-08-2021, 06:10 PM
RE: David Bogen Tuner and Amps - by radiorich - 11-08-2021, 07:43 PM
RE: David Bogen Tuner and Amps - by EdHolland - 11-08-2021, 10:48 PM
RE: David Bogen Tuner and Amps - by EdHolland - 11-18-2021, 08:00 PM
RE: David Bogen Tuner and Amps - by EdHolland - 06-09-2022, 04:21 PM
RE: David Bogen Tuner and Amps - by radiorich - 06-09-2022, 07:29 PM
RE: David Bogen Tuner and Amps - by EdHolland - 06-10-2022, 03:41 PM
RE: David Bogen Tuner and Amps - by radiorich - 06-10-2022, 06:46 PM
