Suggestions for a good digital signal/function generator?
Yes this is the one.
I forgot I put a small resistor in there, it is optional as the current is limited. And if you touch a real high voltage (not a grid capacirance charged to it) the resistor won't help.
This jig is to take care of smaller charges with self limited discharge. Transorbs for Telecom signals could be used also. Otherwise a real serious protection device is needed.
RE: Suggestions for a good digital signal/function generator? - by morzh - 09-27-2019, 10:05 PM
Eico 232 VTVM Schematic
There are currently 3185 online users. [Complete List]
» 2 Member(s) | 3183 Guest(s)
