Latest on the 37-650
I think you need to start over aligning it. At least it squeals and howls at the low end and you get something worthwhile on the high end, that (to me) is a good thing, and it means you're on the right track.
Not having the instructions in front of me, and the alignment I did was about 6 years ago, I'm a little foggy on the details, but I think we can all smell sucess coming! Icon_smile
Don't give up!
Bill
Sent from my Pentium II on the AT&T Dial Network
Latest on the 37-650 - by Robbie Roberts - 02-21-2006, 10:57 PM
[No subject] - by Bill Hutchinson - 02-22-2006, 06:39 PM
[No subject] - by Robbie Roberts - 02-22-2006, 06:41 PM
[No subject] - by Bill Hutchinson - 02-22-2006, 06:50 PM
[No subject] - by Chuck Schwark - 02-22-2006, 07:35 PM
[No subject] - by Robbie Roberts - 02-22-2006, 07:38 PM
[No subject] - by Chuck Schwark - 02-22-2006, 08:29 PM
[No subject] - by Robbie Roberts - 02-22-2006, 08:35 PM
[No subject] - by Steve Chambers - 02-22-2006, 08:44 PM
[No subject] - by Robbie Roberts - 02-22-2006, 08:47 PM
[No subject] - by Chuck Schwark - 02-22-2006, 09:00 PM
[No subject] - by Robbie Roberts - 02-23-2006, 12:56 AM
[No subject] - by Derek D - 02-23-2006, 01:33 AM
[No subject] - by Robbie Roberts - 02-23-2006, 01:40 PM
There are currently 5298 online users. [Complete List]
» 2 Member(s) | 5296 Guest(s)
