Latest on the 37-650
If all you did was replace the lead wiring to the coils, IMHO, that shouldn't make a major difference - if it's only a few inches we're talking here that ought to be insignificant. Anyone who knows more on this topic than me (which is probably many of you Icon_redface ), feel free to chime in.
If the original coils are intact and you have continuity, it should be fine. I think what probably counts more are the number of turns in the coil than actual resistance itself (again, correct me if I've mis-typed), which would throw off the resonant frequency if the wrong number of turns were on the coil.
Bill
Sent from my Pentium II on the AT&T Dial Network
Latest on the 37-650 - by Robbie Roberts - 02-21-2006, 10:57 PM
[No subject] - by Bill Hutchinson - 02-22-2006, 06:39 PM
[No subject] - by Robbie Roberts - 02-22-2006, 06:41 PM
[No subject] - by Bill Hutchinson - 02-22-2006, 06:50 PM
[No subject] - by Chuck Schwark - 02-22-2006, 07:35 PM
[No subject] - by Robbie Roberts - 02-22-2006, 07:38 PM
[No subject] - by Chuck Schwark - 02-22-2006, 08:29 PM
[No subject] - by Robbie Roberts - 02-22-2006, 08:35 PM
[No subject] - by Steve Chambers - 02-22-2006, 08:44 PM
[No subject] - by Robbie Roberts - 02-22-2006, 08:47 PM
[No subject] - by Chuck Schwark - 02-22-2006, 09:00 PM
[No subject] - by Robbie Roberts - 02-23-2006, 12:56 AM
[No subject] - by Derek D - 02-23-2006, 01:33 AM
[No subject] - by Robbie Roberts - 02-23-2006, 01:40 PM
There are currently 9924 online users. [Complete List]
» 1 Member(s) | 9923 Guest(s)
