How to safely remove a 37-620 viewing glass
Hi and welcome,
Use your palm to press in on the metal surface. gently twist to the left (in think or to the right). Remove the outer ring and glass. Under it there are 4 screws to remove the rest.
RE: How to safely remove a 37-620 viewing glass - by Radioroslyn - 10-04-2019, 04:02 PM
Philco 91 Tuning Condenser
There are currently 3758 online users. [Complete List]
» 2 Member(s) | 3756 Guest(s)
