PT 87 speakers
Why did Philco use 2 types of speakers in these portables ?  Some have the usual PM type and others use a magnetic type that was outdated over a decade before the 41-42 series.
PT 87 speakers - by Phil3815 - 10-08-2019, 02:53 PM
RE: PT 87 speakers - by Ron Ramirez - 10-08-2019, 05:34 PM
RE: PT 87 speakers - by mikethedruid - 10-08-2019, 05:58 PM
Philco 91 Tuning Condenser
