Loktal Philco only?
Thanks Mike.
Ron indicated earlier that Philcos came with (glass) Sylvanias, as opposed to the metal tubes RCA  and others used.  I think  Zeniths  were included,
and they must have continued on with the Loktal versions when the came out.
Loktal Philco only? - by Jake Blake - 10-13-2019, 09:16 AM
RE: Loktal Philco only? - by Radioroslyn - 10-13-2019, 01:42 PM
RE: Loktal Philco only? - by morzh - 10-13-2019, 02:14 PM
RE: Loktal Philco only? - by Jake Blake - 10-13-2019, 05:25 PM
RE: Loktal Philco only? - by Jake Blake - 10-13-2019, 05:30 PM
RE: Loktal Philco only? - by Tucker - 10-14-2019, 07:53 PM
RE: Loktal Philco only? - by Jake Blake - 10-14-2019, 07:55 PM
RE: Loktal Philco only? - by amptramp - 10-14-2019, 10:05 PM
RE: Loktal Philco only? - by Tucker - 10-15-2019, 06:59 AM
RE: Loktal Philco only? - by mikethedruid - 10-15-2019, 01:52 PM
RE: Loktal Philco only? - by EdHolland - 10-15-2019, 08:23 PM
RE: Loktal Philco only? - by Jake Blake - 10-15-2019, 09:08 PM
RE: Loktal Philco only? - by Tim Tress - 05-08-2020, 07:37 PM
RE: Loktal Philco only? - by amptramp - 10-03-2020, 07:31 PM
Philco 91 Tuning Condenser
There are currently 10555 online users. [Complete List]
» 1 Member(s) | 10554 Guest(s)
