any value in this or should I make a trip to the dump?
Forgot to mention...the chassis of the 40-508 is similar to, but not exactly the same as, a 40-150/155/180/185/190. The 508 uses two 42 output tubes and an 80 rectifier; the others use two 41 tubes and an 84 rectifier.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8736 online users. [Complete List]
» 3 Member(s) | 8733 Guest(s)
