Philco 41-295
So here's where I'm at.  final coats of lacquer have been applied.  I'll wait a few weeks for it to completely dry and cure (using pre-cat lacquer).  I have a couple of small runs to sand out and then finish sand with wet 400, 600, 1200, and maybe 2000 grit paper.  Then rub out with polishing compound.  A freakin lot of work!
The white wood has lots of filler to fill dents so it was toned with a light color, opaque toner to hide the repairs, then toned with Medium Brown Walnut and VanDyke brown.  It may be a bit darker than original but all my less than professional repairs are hidden.  Grain filler was Mohawk walnut sealed with EZvinyl sealer.  Then mohawk sanding sealer. Then semi-gloss pre-cat lacquer.  The walnut top and sides have only a very tiny bit of medium walnut toner, otherwise it is the color of the wood after the grain filler was applied after a wash coat of sealer.  The diffusers are easy to remove so they were finished separately from the cabinet.
I have a really hard time with the rattle cans of toner.  I can't get an even color.  This cabinet is practice for an EH Scott I need to refinish so I've learned that I may need to mix my own toner and spray with a gun for a more even color.
Philco 41-295 - by rfeenstra - 10-09-2019, 09:16 AM
RE: Philco 41-295 - by Ron Ramirez - 10-09-2019, 12:29 PM
RE: Philco 41-295 - by rfeenstra - 10-09-2019, 04:46 PM
RE: Philco 41-295 - by rfeenstra - 10-09-2019, 05:03 PM
RE: Philco 41-295 - by Ron Ramirez - 10-09-2019, 06:11 PM
RE: Philco 41-295 - by rfeenstra - 10-09-2019, 07:02 PM
RE: Philco 41-295 - by Ron Ramirez - 10-09-2019, 07:26 PM
RE: Philco 41-295 - by Paul Philco322 - 10-09-2019, 08:51 PM
RE: Philco 41-295 - by rfeenstra - 10-09-2019, 09:17 PM
RE: Philco 41-295 - by nortonz - 10-10-2019, 01:24 AM
RE: Philco 41-295 - by rfeenstra - 10-10-2019, 09:42 AM
RE: Philco 41-295 - by nortonz - 10-11-2019, 02:13 AM
RE: Philco 41-295 - by rfeenstra - 10-11-2019, 10:16 AM
RE: Philco 41-295 - by rfeenstra - 10-19-2019, 10:32 PM
RE: Philco 41-295 - by nortonz - 10-19-2019, 11:37 PM
RE: Philco 41-295 - by rfeenstra - 10-19-2019, 11:52 PM
RE: Philco 41-295 - by rfeenstra - 10-20-2019, 09:44 PM
RE: Philco 41-295 - by nortonz - 10-21-2019, 03:03 AM
RE: Philco 41-295 - by rfeenstra - 10-21-2019, 09:14 AM
RE: Philco 41-295 - by nortonz - 10-21-2019, 01:26 PM
RE: Philco 41-295 - by rfeenstra - 10-22-2019, 09:32 PM
RE: Philco 41-295 - by rfeenstra - 10-31-2019, 08:56 PM
RE: Philco 41-295 - by Jake Blake - 10-31-2019, 09:01 PM
RE: Philco 41-295 - by nortonz - 11-06-2019, 12:56 AM
RE: Philco 41-295 - by rfeenstra - 11-06-2019, 10:43 AM
RE: Philco 41-295 - by morzh - 11-06-2019, 11:21 AM
RE: Philco 41-295 - by nortonz - 11-07-2019, 10:47 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9395 online users. [Complete List]
» 2 Member(s) | 9393 Guest(s)
