Loose wire...
Morning !
Looks like it should go over the to pin 4 or 5 ( should be hooked together ) of the 77 mixer tube.
It's part of the oscillator feedback circuit. It's common on these set of the feedback winding to
rot and on open. Your wire may have been disconnected to troubleshoot the coil.
ps Replace your filter condenser both sections lest you want to replace both section of the filter the 80 tube and the power transformer later!
Loose wire... - by Kico - 01-03-2011, 09:50 AM
Re: Loose wire... - by 7estatdef - 01-03-2011, 10:08 AM
Re: Loose wire... - by Kico - 01-03-2011, 10:24 AM
Re: Loose wire... - by 7estatdef - 01-03-2011, 12:14 PM
Re: Loose wire... - by Kico - 01-03-2011, 12:33 PM
Re: Loose wire... - by 7estatdef - 01-03-2011, 03:01 PM
Re: Loose wire... - by Kico - 01-05-2011, 05:47 PM
Re: Loose wire... - by 7estatdef - 01-05-2011, 06:16 PM
Re: Loose wire... - by gary rabbitt - 01-05-2011, 11:18 PM
Re: Loose wire... - by gary rabbitt - 01-06-2011, 01:02 AM
Re: Loose wire... - by Kico - 01-06-2011, 03:19 PM
Re: Loose wire... - by 7estatdef - 01-06-2011, 07:34 PM
Re: Loose wire... - by Kico - 01-06-2011, 08:51 PM
Re: Loose wire... - by 7estatdef - 01-06-2011, 09:33 PM
Re: Loose wire... - by Kico - 01-06-2011, 09:47 PM
Re: Loose wire... - by 7estatdef - 01-06-2011, 10:32 PM
Re: Loose wire... - by Kico - 01-07-2011, 04:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 6630 online users. [Complete List]
» 2 Member(s) | 6628 Guest(s)
