Chassis ID....
Either 620 or 625. Most likely 625 rather than 620 since it has the moving piece to shift the dial light to the selected band which makes its arrow "glow" (a feature the 620 did not have). Not a chairside (no brackets, no upside-down dial scale). Bottom shield indicates it came from a console cabinet.
Chassis ID.... - by OldRestorer - 10-21-2019, 09:13 AM
RE: Chassis ID.... - by Ron Ramirez - 10-21-2019, 11:33 AM
RE: Chassis ID.... - by OldRestorer - 10-21-2019, 12:28 PM
RE: Chassis ID.... - by Ron Ramirez - 10-21-2019, 01:12 PM
Philco 91 Tuning Condenser
There are currently 4865 online users. [Complete List]
» 2 Member(s) | 4863 Guest(s)
