Is it worth it?
You should be aware that is a 39-55RX, not a 39-116RX. Notice it is AM only. It's just a basic AM radio with the added novelty of wireless remote control. To me it wouldn't be worth the effort to drive 5 minutes both ways to get it for $5, but then again I really don't care for those sets. We all like different stuff, that's what makes this hobby so neat and interesting - there are different radios to suit everyone's likes. Icon_smile
Is it worth it? - by Scott D - 10-21-2019, 08:35 PM
RE: Is it worth it? - by Chas - 10-21-2019, 11:36 PM
RE: Is it worth it? - by OldRestorer - 10-22-2019, 05:04 AM
RE: Is it worth it? - by Ron Ramirez - 10-22-2019, 07:44 AM
RE: Is it worth it? - by Phlogiston - 10-22-2019, 09:58 AM
RE: Is it worth it? - by Scott D - 10-22-2019, 10:51 AM
Philco 91 Tuning Condenser
