Loose wire...
Value isn't critical you could go as high as 47mfd or so. Back in the 1920's and 30's electrolytics where expensive to make so most of the filtering is done with inductance. If you look at diagrams say of a Philco model 87 the filters are like 1 or 2mfd and two or three chokes. Very important to observe polarity and voltage rating. 450v for this one. Philco in the '30s some times would use a small paper cap across the filter choke a help resonate L/C to 60cy.
Have Fun & happy new year!
Loose wire... - by Kico - 01-03-2011, 09:50 AM
Re: Loose wire... - by 7estatdef - 01-03-2011, 10:08 AM
Re: Loose wire... - by Kico - 01-03-2011, 10:24 AM
Re: Loose wire... - by 7estatdef - 01-03-2011, 12:14 PM
Re: Loose wire... - by Kico - 01-03-2011, 12:33 PM
Re: Loose wire... - by 7estatdef - 01-03-2011, 03:01 PM
Re: Loose wire... - by Kico - 01-05-2011, 05:47 PM
Re: Loose wire... - by 7estatdef - 01-05-2011, 06:16 PM
Re: Loose wire... - by gary rabbitt - 01-05-2011, 11:18 PM
Re: Loose wire... - by gary rabbitt - 01-06-2011, 01:02 AM
Re: Loose wire... - by Kico - 01-06-2011, 03:19 PM
Re: Loose wire... - by 7estatdef - 01-06-2011, 07:34 PM
Re: Loose wire... - by Kico - 01-06-2011, 08:51 PM
Re: Loose wire... - by 7estatdef - 01-06-2011, 09:33 PM
Re: Loose wire... - by Kico - 01-06-2011, 09:47 PM
Re: Loose wire... - by 7estatdef - 01-06-2011, 10:32 PM
Re: Loose wire... - by Kico - 01-07-2011, 04:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 4556 online users. [Complete List]
» 1 Member(s) | 4555 Guest(s)
