Found—Model 40-150 in Chinese black lacquer highboy cabinet
Hi. My first post to this forum. I am about to begin my first restoration on a model 40-150 I recently found on the side of the road. I'm curious to know if this cabinet style was common. I haven't seen any images of it on this site or others. Any thoughts/info/history on this would be greatly appreciated. Sorry for the limited angles...shot from the back of my car.
There are currently 10225 online users. [Complete List]
» 2 Member(s) | 10223 Guest(s)
